TwinTurbo.NET: Nissan 300ZX forum - An easy gauge check
Subject An easy gauge check
Posted by ConVerTT on April 03, 2010 at 11:02 AM
  This message has been viewed 93 times.
In Reply To not sure if I read that correctly, but sounds like you have posted by LJZTT on April 03, 2010 at 05:20 AM
Message Pick up a cheap boost gauge - 40 0r 50 bucks from your favorite auto
parts store and a plastic T connector and a 3 or 4 ft length of vacuum
hose.
Tap into one of the vacuum hoses that connect to the balance tube at the
back of the engine.
Run the vacuum line under the hood over the cowl and through your
window so you can read it.
Drive car ....
Report back with results
